So I am going to be switching out some outlets in my home. It’s my first time doing this specific project but I have done extensive research and watched lots of YouTube videos so I know prior to changing the outlet I need to...
Also… The current outlet is an old (i think 80's) 3 prong but does not have a ground wire (see photo). I plan to replace it with a preferred Leviton outlet that has the grounding tab (see photo). Since the new outlet has a grounding tab, I should be good to go right? OR should I install a GFCI outlet instead?
Let me know if there are any other questions i should be asking, any info from your experience is greatly appreciated! Thanks
- Turn off the breaker
- Double check the outlet and wires with voltage meter/tester. I plan to use a few different types of voltage testers to make triple sure
