Embarrassing Question of the Day: how do you accurately measure and mark holes for drilling?
2.9K views 8 replies 7 participants last post by  DexterII
for instance, let's say i want to make a hole in the wall 1 foot from the floor and 3 feet away from the end of the wall?
for example yesterday i was drilling holes to hang some blinds. i needed to drill the holes 4" from the edge of the trim and 0.5" in. i used a tape measure to get both measurements and then made 2 marks. i assume there's a smarter way.
#3 · (Edited)
If I have a lot of blinds to hang, I just make a template out of scrap wood. Start with your measurement on your preferred side, drill you holes in the template and then drill your holes in the wall using the template. Flip the template over and drill the holes on the other side of the window. That way, all holes are the same.
Stiff cardboard will work as well. I have also used an old deck of playing cards in a pinch
#7 ·
You're working on a plane, and need an up and down and a left to right, two measurements, so yeah, you've got it. More often than not I will use a folding rule for things like that, but it's only a matter of personal preference, and comes out the same with a tape measure. And I'll often use tape as SPS suggested, especially if I want to step back and take a panoramic view, but if you're locked into a specific width or whatever and have a good eye sometimes you can get by with some little marks that won't show anyway.
#9 ·
I don't what made this pop back into my head, but I mentioned having to account for up and down and left to right, or essentially the x and y axis, and you sort of implied being a novice, so I probably should have mentioned the z axis as well. Electricians are required to keep the edges of any of their holes a minimum 1-1/4" from the face of the stud, or, if this is not possible, they are required to place a steel nail plate on the stud to protect the cable. So keep in mind that any time you drill, nail, or screw into a stud the penetration should not exceed 1-1/4", and if you hit a steel plate STOP. I seriously doubt that any of the hardware you're using on this project is any where near this deep, but something to stick in your back pocket.
