Stud right where light box needs to go..
49K views 44 replies 17 participants last post by  CharlieR
Hello,
I was wondering, not sure if it's a local code thing or not, if a non-load bearing stud can be notched for a light box on a wall? I'm trying to center a lamp right over the middle of a sink, and unfortunately, there is a stud right there. SO I was wondering if it's ok to notch it enough to put the box basically in the stud? I know there are those pancake boxes, but would rather not do that. I can/will sister the stud just in case...
Other options are offsetting the box and getting a light fixture with a large enough wall plate to cover it, but Id rather not unless notching the stud really isn't to code or a good idea.
THoughts/opinions/advice? Thanks in advance....
Charlie
Nothing I suppose... I think you're only suppose to have the fixture and one set of 14g wires coming in right? My original plan was to have the power enter this fixture, and then go to the next and then to the switch, so I"d have to rearrange that... plus feeding the fixture first, so that would be 3 14g, plus the fixture wires....is that not too much even if I did change my plan?
#9 ·
Thanks Stickboy, thanks Brric.
Moving the stud... is difficult. THere is an intact room on the other side of the bathroom. So the plaster wall on the opposite side is still attached!
I'm guessing both of you think notching the stud is a *bad* idea? The pancake box might be promising....
#21 · (Edited)
Electricians are always notching studs that I put in. Some, note, gentlemen, I said "some", have no idea if it is load bearing or not, or how much they can cut out. At least they're not as crazy as some plumbers, who will cut out an entire section of stud to run a 3" line.
If you are absolutely sure this is non load bearing, ( and I should ask how you know it is not load bearing before I continue) there should be no problem in notching it. As long as you do not notch deeper than 40% of stud. In a 2x4 that's 1 7/16". And notch should be as low as possible.
Occasionally a stud will warp or bend if notched because of they way wood fibers of grain run and inter-mesh. If the wall is open on this side, you said you could sister the stud so I assume it is, it would be best to put in a new or couple of new studs on each side of notched one, rather than notched sisters.
Reactions: stickboy1375
#22 ·
Thanks notmrjohn,
I guess I don't know 100% that it is not load bearing. It runs perpendicular to an outside (obviously load bearing) and an interior non load bearing hallway wall. I assume the hallway is not load bearing becuase the otherside of the hallway appears to be, becuase it runs down through the house all the way to the basement on what I believe are load bearing walls. Now, there are several of these perpendicular walls, in each of the rooms along the hallway. Only two of them have walls on the main floor beneath. Is it safe to assume then that bathroom wall is not load bearing since there isn't anything underneath it?
Im ok with adding studs on either side as well. Other than having to run piping through them!
#24 ·
gregzoll said:
Sbulime, no 2" will not be noticeable when it comes down to it. As for the pancake boxes, they make them so that you do not have to notch out the stud, you just have to cut the drywall to be able to secure the straps to both sides of the stud.
Maybe not in your bathroom .......
What if the wall he's dealing with is say, 20" in width?
You will see it.
#28 ·
CharlieR said:
Hello,
Charlie
Depends on what type of light you ate installing. I you are using a light where there is a mounting plate (the length of your fixture) you can mark your centre mark on your mounting plate and drill a hole through the plate and put a plastic bushing in it and mount your fixture with toggle bolts
#29 ·
The problem with a pancake is they are only 6 cu in, enough for a single 14-2. If you have a single 20 amp circuit for the bath (lights and recept), you can not connect a single 12-2 to a pancake (and meet code).
#31 ·
rjniles and oso954, those are interesting boxes... I wonder if those are code up here in Ontario, as I was planning on getting it inspected even though I was doing it myself. Thats actually a neat idea.
I have a 14g circuit for the lights and bath fan, and a 14g for the recepticals. SOooo I could change my wiring plan to make use of the pancake.
THanks for everyone's input, this site is great!
#35 ·
CharlieR said:
Unfortunately, it's almost dead center on the stud. I can shift left or right a bit based on moving the vanity a bit in either direction.
Nail a new stud along side of the existing stud then notch the existing stud and install box on the new stud right where the notch is.
