In looking for window headers, it was suggested to me to stack two beams, one of which is not quite of sufficient stiffness to carry the load. I don't like the idea real well, and here is my thinking: If you stack two identical beams atop one another, does the lower one really add much? It seems to me that the second one adds very little. (Assume a uniform load on the beams.) If the upper beam, A, bends, it will bend more in the middle than anywhere else, which puts a point load on the lower beam, B. A beam w/ a point load in the middle carries about 1/8th as much as it would if loaded uniformly. (That is not a statement of fact, but rather my understanding only.) IF that is true, then beam B does not add much initially, but will add more and more as the beams bend, albeit marginally increasing. That said, if there is a window below these two beams the window would likely crack before the beams acted as one. Now, if you gusset the two beams with plywood on each side, you still have not added much, as plywood is not the greatest beam material because alternate lams go in the wrong direction. Thus, it seems almost pointless to stack two beams, and several magnitudes better to just buy a taller beam. Anyone know this stuff for sure? Got numbers? Thanks.
