Strengthening Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 04:18 PM   #1
strengthening floor joist
i need to strengthen my floor joist so i can lay a tile floor in my kitchen. my plan is to glue 6" strips of osb to the side of my 2x8 joist then glue and nail a 12' 2x6 to the osb. the reason for the 2x6 is with wires and other utilities i can in most places fit a 2x6 in tight to the floor board. is this a waste of money for what i might gain in strength? i've read about glueing 2x4 to bottom of joist but dont think its an option due to the condition of my joist. with cut outs of the joist on bottom i dont think i would have a solid enough bond for it. opinions please.
jpaz is offline   Reply With Quote
Old 08-19-2011, 06:06 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
And the OSB will accomplish what.........?
XXX
Old 08-19-2011, 06:11 PM   #3
Framing Contractor
Why are there cut outs on the bottom of your joists...and how many joists have cut joists?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-19-2011, 07:27 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
One of the best ways to stiffen up the floor joist is to rip a 4x8 sheet of 1/2" OSB into 7" wide strips. I'm assuming your floor joists are 2x8 12' long....If that is the case, one strip will be the full 8' long...the second strip will be 4' long.
Then take those OSB strips and glue and screw them to the floor joist (with no load on the floor) If you have some deflection already...maybe use a jack to level the floor.
Alternate where the 4' sections are...every other joist....
Give the glue time to dry....at least a day....that will stiffen up the floor quite a bit.
Another option....install more floor joists....not that hard...cut to length...insert...use a BFH to knock them into postion.
Old 08-20-2011, 09:58 AM   #5
bud, i thought the osb would add alittle extra strength, not sure if im saying this right but doesnt it add tensle strength? is this not a good option? as far as the cut outs that joe asked about, my house is over a hundred years old and previous owner over time found it not to be an issue to cut out sectins of joist for any reason, mostly for duct work and even gas & water lines. maybe 6 out of 14 have somthing cut out. one even shaved to 1" in a 2' section.
Old 08-20-2011, 10:05 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would think plywood would be the product to use if you go that route. OSB isn't that strong under those circumstances.
I guess you know there are prescribed limits as to how much you can cut away from a floor joist and where (within the joist) those cuts can be made. Same goes for drillings in them. Sounds like some of yours are way over the limits.
XXX
Old 08-20-2011, 10:09 AM   #7
DIY staff
Rewards Points: 7,174
Post some pictures----
Old 08-20-2011, 02:01 PM   #8
Registered User
Rewards Points: 5,204
Good shear strength.OSB is stronger than plywood in shear,” says a report by the Building and Construction Technology program at University of Massachusetts--Amherst. “Shear values, through its thickness, are about two times greater than plywood. This is one of the reasons OSB is used for webs of wooden I-joists.” From: http://www.ecohomemagazine.com/green...od.aspx?page=2
If the joist bottoms are compromised in the middle 1/3, we really need pictures, as Mike said: http://www.mybuildingpermit.com/Cons...Sheet06_11.pdf
Will any other option work other than #3, here? http://www.finehomebuilding.com/PDF/Free/021184090.pdf
The 2x6’s will add little to future loads is already sized for 2x8’s…
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AndyGump (08-20-2011)
Old 08-20-2011, 05:19 PM   #9
JOATMON
ddawg16's Avatar
Good find GBR....better than the one I was going to post.
OSB has a significant shear strength....OSB vs plywood.....a discussion for another day....each has advantages....with plywood typically being a slightly better choice for floor and roof sheathing...but plywood tends to have a shear strenght greater in just one direction...whereas OSB has equal shear in all directions.
I know a couple of guys that did the OSB glued to floor joists thing....they said it made a significant difference....in one case it was to some 2x6's in the ceiling joist of his garage. Before the OSB, he had about a 1" drop in the middle. After OSB, maybe an 1/8" drop at most. And adding weight up there (storing his junk) caused maybe another 1/4" drop.
Let me stress...for it to work properly....it must be attached properly. The glue is what helps keep the deflection down...and the nails help prevent the deflection from breaking the bond on the glue.
Old 08-20-2011, 07:24 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What does the "shear-strength" of OSB have to do with using it for scabs to improve deflecting floor joists? Shear doesn't enter into it.
I can't argue with OSB manufacturers or organizations hyping their product but common sense tells me that using OSB slabs for joist-scabs doesn't involve shear stresses of the OSB. The shear-factors in this case have to do with the adhesive and the fasteners only. Is that not true? What am I missing?
XXX
Old 08-20-2011, 08:11 PM   #11
JOATMON
ddawg16's Avatar
A LOT.....
OSB is not the best thing to use for say shelves....it's strength pependicular to the plane of the sheet is not that great.....that is where plywood has the advantage...
But its deflection along the same plane (shear) is excelent when compared to sawn lumber. That is why you see it used in engineered joists...they basically take a 10" strip x number of feet long and cap each edge with a 2x2 to give you the equivilant of a 2x12 but with much better deflection. In cases where you would be required to use 2x12's on 12" OC, you could use engineered joists 16" OC.
One important point....adding OSB strips to your existing floor joists is not the way to increase your load bearing strength. Your existing floor joists need to be sized for the live and dead load. Yes, it does increase the load...but you can't factor that into the load calculations.
Sawn lumber tends to have some flex in it...so floors tend to be bouncy with it....the OSB does not flex...hence, it helps the joists by reducing the flex.
A good analogy for any of you mechanical guys would be comparing a composite structure to an aluminum one....for a given part, both have the same strength...but the al one will bend quite a bit before it breaks...where as the composite one...not much....
Old 08-20-2011, 08:38 PM   #12
Civil Engineer
Rewards Points: 4,562
I am not interested in starting a flame war, however it is reasonable to expect that posts have some relevance, and be factually correct. So let's set the record straight on the significance of shear strength AS IT PERTAINS TO DEFLECTION of a structural element, which is what we are talking about here.
The deflection of a structural element under bending load (we are talking about bending loads here, because the element we are discussing is a horizontal beam or joist loaded along the length of the element) depends on the following factors:
1. The moment of inertia of the element. The greater the moment of inertia, the lower the deflection. Moment of inertia increases as the cube of the depth, and is linear with the width of the element.
2. The modulus of elasticity of the element. The greater the modulus, the lower the deflection. Steel has a modulus about 20 times that of wood, therefore a steel beam of the SAME SHAPE as a wood beam will deflect approximately 20 times less than the equivalent shaped wood beam. This is a discussion about deflection, NOT strength.
3. The load. The greater the load, the greater the deflection. In this case, we are comparing structural elements under identical load, so this factor does not come into play.
So let's see what this tells us. If you take a sawn wood element like a 2x10 and uniformly load it, you will get maximum deflection at the center. If you strengthen this element by sistering another 2x10 to the first one, you will have doubled the moment of inertia, and the deflection will be half that of a single element, under constant loading. If you attach another 2x10 to the bottom of the first 2x10, making effectively a 2x20, the moment of inertia is now 8 times as large, and the deflection is 1/8 that of a single 2x10.
The kicker is that you will have a much deeper beam, and you need to glue and/or nail the second 2x10 onto the first adequately so that you carry the full amount of horizontal shear generated at the interface. This is HORIZONTAL shear, not vertical shear. If you do this, you get a composite beam with 8 times the moment of inertia, and 1/8 the deflection. Again, this is NOT a discussion about strength, merely deflection.
If you nail on a piece of OSB which is 1/2 inch thick and 9.5 inches deep to the side of the 2x10, you will increase the moment of inertia of the composite section by approximately 1/3 (1/2 inch is 1/3 of 1.5 inches, the presumed width of the 2x10). Assuming the modulus of the OSB is approximately the same as that of the sawn lumber, which it usually is, the deflection will be approximately 1.5/2 = .75, so there will be a 25% decrease in deflection. You get exactly the same result if you nail on a 1/2 inch thick x 9.5 inch thick piece of plywood or sawn lumber, assuming the modulus of elasticity of the nailed on piece is the same as the lumber, and it is usually close. This assumes you use an adequate number of nails and/or glue to resist the horizontal shear induced by the composite action of the beam under load.
Note that in this discussion of deflection, the issue of vertical shear has NOT COME UP. Vertical shear almost never controls in residential construction, and it is therefore irrelevant in the case of deflection how strong plywood or OSB is in vertical shear (vertical shear is normally just called shear), therefore Bud is exactly correct, it makes no difference for this discussion how strong in shear OSB is vs. plywood. We also had no need to discuss strength to determine deflection. In the real world, the engineer designing your beam always checks the structural element for strength and deflection, and sizes the beam based on the more restrictive condition.
Conclusion: It is perfectly reasonable to stiffen a beam or joist by nailing/gluing on plywood, OSB or sawn lumber. It is more effective to attach the new wood to the bottom of the existing beam, but this is rarely done because of the difficulty in getting adequate attachment to the bottom to resist horizontal shear. The most effective choice would be the product with the greatest modulus of elasticity, however since they are all about the same, the grand conclusion is it makes little difference which type you use.
Note: You need to do some deflection calculations before you go nailing or gluing to your existing joists, since you need to know how thick an addition you need to make.
Daniel Holzman is online now   Reply With Quote
The Following 4 Users Say Thank You to Daniel Holzman For This Useful Post:
AndyGump (08-20-2011), Bud Cline (08-21-2011), M3 Pete (05-10-2012), SteelToes (08-22-2011)
Old 08-20-2011, 11:52 PM   #13
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
I read everything Daniel writes with great interest and he never fails to impress.
Andy.
AndyGump is offline   Reply With Quote
Old 08-21-2011, 12:06 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Great explanations guys. Thank you.
My concern is more about how the OSB will handle the screw heads over time (1). The use of adhesive is a must but what type of application would a guy use is my concern (2). A few squiggles squeezed from a tube wouldn't be the answer for me. And if squiggles were the method of choice how would the waffered OSB handle each squiggle at each squiggle site?
I guess it is a matter of preference and my preference would be plywood way over OSB for this application.
I don't argue the strength of OSB when used as a web dado-ed between two wood flanges as with I-joists. But this use is a totally different application.
I have work benches in my garage that began shedding wafers after a few years. I have to keep them sealed to control the shedding. They have never once been wet, never. The only moisture they have seen is atmospheric moisture on a regular basis. I also have portable work benches that I have waterproofed and even then they separate from the inside out after a time.
I just wouldn't trust OSB in the above application.
Excellent information tho.
XXX
Old 08-22-2011, 10:12 AM   #15
thank you all for the info. i would love to post pictures, i'm sure it would help but at this point i am not able to. so from what i gather is osb vs plywood doesn't make much difference, but with moisture in the basement the osb may swell and de-laminate. but what i wasn't aware of is how very little it may help. i'll be honest i dont know alot about deflection, but i was reading a earlier post about joist and deflection, i was surprised at how the numbers went up very little with sistering as opposed to almost triple with a support beam. my joist still need work for sure, but maybe i should consider a support beam also. yes its in a area where we walk for washer & dryer but maybe i could use somthing like steel 4" or 6" wide c-channel?
Strengthening a bouncy floor jdelisle Building & Construction 13 10-30-2012 06:47 PM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 08:28 PM
Strengthening an old garage DaleBelcher2 Building & Construction 0 06-11-2010 01:11 PM
Strengthening ceiling/floor Steve Burke Remodeling 1 01-24-2010 12:11 AM
strengthening an existing beam ericw1 Building & Construction 7 07-29-2009 06:44 PM
