I currently do not have an air vent for our kitchen sink and dishwasher. I installed an AAV under the sink as a temporary solution until the weather gets nice and I can get up on the roof. Please keep that in mind when answering this question as I do not plan to keep this permanent. I know a lot of people do not like them and this is only a temporary solution. I would really like to get this working for the time being.
This is how I installed it under the sink. I've tried both of these AAV and neither work.
http://www.homedepot.com/p/Oatey-Sur...9016/100201861
http://www.homedepot.com/p/Oatey-1-1...9012/100204205
When I turn the water on after about 1 minute the sinks starts to back up like it can't drain. All I have to do is unscrew the AAV and the water rushes down the drain and I can feel the air being sucked in by my hand. The 2nd I screw the AAV down it stops draining.
The trap inside the AAV is not opening. I can confirm this on both models that I have put in. It is over 4" above the trap. It's almost as if there isn't enough suck-ton to open the valve. I find that hard to believe though since the 2nd I unscrew it the amount of suck-ton that I feel by my hand while unscrewing it.
Any idea's or things to try? The problem seems to be that the flap on the AAV is not opening on both models.
