Is This Legal - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2014, 04:35 PM   #1
Rob
Robpo's Avatar
Rewards Points: 826
Is this legal
I live in Elko county NV. I am building a mother-in-law cottage. When I finished gluing/welding the dwv for the shower I thought I should have done it different. What do you think? Should the vent be on the top and drain on the side? Is this legal? Should I rip it out and do it over or leave it the way it is?
Edit: Forgot to mention it is underground plumping with concrete slab
Robpo is offline   Reply With Quote
Old 03-30-2014, 04:50 PM   #2
Rewards Points: 320
Welcome to the forum Robpo. Please wait for the plumbers to look at your pic and respond to your post. Eplumber and ghost know ipc and upc codes and will let you know if what you have there meets code. Thanks. If you do have to redo it, the good thing is it won't cost much in parts. Thanks.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Robpo (03-30-2014)
Old 03-30-2014, 05:21 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
It is not illegal (against the law) but it is not code compliant. To vent it properly replace the 90 with a tee and take the vent out of the top of the tee.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
jmon (03-30-2014), Robpo (03-30-2014)
Old 03-30-2014, 06:10 PM   #4
Rewards Points: 582
that would be clasified as a wet vent...vent should be above the flow line..some areas allow for wet venting..but imo its not a good vent system.. if you can rip it out and redo it with vent off top..
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
plummen (04-29-2014), Robpo (03-30-2014)
Old 03-30-2014, 06:35 PM   #5
joed's Avatar
Rewards Points: 13,346
Or just swap the connection point for the drain and the vent so the vent is on the upper line.
Old 03-30-2014, 06:38 PM   #6
Rob
Robpo's Avatar
Rewards Points: 826
Yea, I plan an ripping it out and thanks for the explanation because my wife asked me why it was not code compliant.
The Following User Says Thank You to Robpo For This Useful Post:
jmon (03-30-2014)
Old 03-30-2014, 06:50 PM   #7
Rob
Robpo's Avatar
Rewards Points: 826
I will be able to reuse the trap but everything else, the 2" san tee and 4x4x2 y with 45, I think will be junk.
Old 03-30-2014, 06:53 PM   #8
Rewards Points: 582
you could tie trap into the 2x2x2 tee and take vent off top ...if you have room to cut off the 90....
Old 03-30-2014, 07:17 PM   #9
Rob
Robpo's Avatar
Rewards Points: 826
no room it's street tee. or maybe a street 90, I forget. When I told my wife I was going to try to reuse it she gave me a look and she is the designer.
Old 03-30-2014, 07:19 PM   #10
Rewards Points: 582
zip zip zip went the saw....you got the right idea....
Old 04-07-2014, 09:00 AM   #11
Rob
Robpo's Avatar
Rewards Points: 826
Got enough good weather to get underground glued. My area is all rock. I have about 3-4 inches of sand in bottom of trench any ideas for bracing. Not sure what code is for bracing I will probably remove it after inspector leaves unless it is actually holding something. I will call inspector later today to find out what else is needed.
http://www.diychatroom.com/attachmen...1&d=1396879048
Old 04-07-2014, 05:38 PM   #12
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,392
Find any gold when you're digging out there.......
MTN REMODEL LLC is offline   Reply With Quote
Old 04-07-2014, 05:53 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 820
He might ask for an end of the line clean out--- mine would
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-07-2014)
Old 04-07-2014, 06:37 PM   #14
Rob
Robpo's Avatar
Rewards Points: 826
E,
Would that be at the toilet end or before the septic end where it leaves the house? When I built my home he wanted it where it left the house.
Thanks,
Old 04-07-2014, 06:42 PM   #15
E,
Thanks,
I'll sure defer to E.... but I thought it was most desirable upstream.
Legal ABS Connection? Klawman Plumbing 7 12-14-2013 02:50 AM
Concrete repair limuel Concrete, Stone & Masonry 15 04-18-2012 08:13 AM
Legal questions - just looking for thoughts Steeler99 Off Topic 2 07-09-2011 11:26 AM
Wow, I got money coming beenthere Off Topic 12 01-21-2010 01:28 PM
