I have everything installed with my Aprilaire 700m except the wiring. I have a Lennox ml195 furnace which contains a 120 VAC HUM terminal. The wiring diagram shows that I need a current sensing relay so that the humidifier only turns on when the blower is on, but isn't that what the HUM terminal is for? The humidifier came with a 24 VAC transformer. I'm assuming I should wire the hot and neutral wires on the primary the transformer with the hot and neutral wires coming in to power the furnace. Is it okay to do this inside the furnace or should it be done at the furnace disconnect switch? With the secondary side of the transformer, I'm assuming one wire should go directly to the solenoid valve and the other wire should go to the humidistat and then wire the humidistat to the solenoid valve.
Are my assumptions correct? Do I need the current sensing relay?
The humidifier itself is going to be plugged directly into an outlet for power so there shouldn't be a need to hardwire that.
Thanks!
Thanks!
