. Ihave an oil burner with a two wire system and was assured by a nest rep that the Nest would work no problem with this setup. I ran a red white and common from my peerless boiler to the nest. Since I've had it I get E74 errors randomly. The thermostat heats up the house and then shuts off. It says under equipment detected no power to Rh. After troubleshooting with a Nest rep today he determined either I need to purchase an isolation relay . The purpose of the isolation relay is to communicate an analog boiler to a digital thermostat.
I'm just a little confused about the wiring diagram included with the relay and was hoping someone could shed some light.
I currently have a red white and common running from the nest to the Taco board at the oil burner. The aquastat also connects to thr same red and white terminals as thr nest.
