Very nice. Now, you said, there wasn't really a need to sand it since you were using BIN primer?
I'm ready to do mines.
The BIN adheres like a mother. Ideally you'd scuff up the surfaces you're putting it on. I may have scuffed them lightly and I did definitely clean them thoroughly first. I imagine that sanding the bin itself after it dries before the top coat would be good but I didn't do much of that.
The best way to have a nice looking job is when using the brush around all the trim go multiple light coats because that's the only way to ensure you don't end up with excessive clumping/dripping, etc. which is the hallmark of a sloppy job
For the roller I used a 6" mini roller (whichever brand has the yellow and blue packaging at lowes).
I also kept the doors off the cabinets for a few weeks to help harden up before putting back into service. I did replace the handles and if you go that route, remote the old knobs, fill the holes with minwax two part wood filler (only two part--don't bother with one-part wood filler). You can get this at lowes, then sand flat and you can add new hardware.
Frankly I found the entire job fairly satisfying, not terribly difficult. Take your time, realize it's going to turn out fine and listen to music. Good luck!
