Where's the rebar?
4.1K views 13 replies 13 participants last post by  mark sr
Where does the residential land survey firm typically drive in the rebar to mark the property
border line? See picture
Do they hammer it in near Point A or 6 feet back from public access rights?
655638
#7 ·
where I live, the iron pipes will be pined exactly on the corners except along a road. From the road, they place the pin 25 feet from the center of the road. like in this image: (NIP= new iron pipe)
655664
if its been a while, the pin could easily be a few inches down. if you are lucky or patient, you can find it with a shovel...
just thinking about it, does your municipality have a GIS site"? an online mapping system for tax and code use? look up your address and the overlay will show the lot boundaries close enough for you to estimate your pin location (see also your platt).
#10 ·
If you have a survey and it does not say 'offset pin' (around here they use a different color cap) then it is on the property line. Sometimes when it is right at the curb they will use a PK nail.
Many older surveys said from the middle of the road but that is more in the country than the city.
#11 ·
The property description, often contained in the deed will mention the property corners. Often it will say 'to a point' which may indicate there is no monumentation or they just didn't find anything. If they set something on an offset, it will say in the description. Some corners are never set, sometimes they can be hard to find. Often you can find the next corner and measure back. Be careful relying on any GIS maps, the surveyors will tell you GIS stands for 'Get it Surveyed". Sometimes very accurate, sometimes not ,they're usually compiled from records, not actual surveys.
#12 ·
Our primary residence is in an area where long ago the property was measured to the centerline of the road and it stayed that way. The municipality has a right of way across our property for their road. In the unlikely event that the road got abandoned, we would resume full ownership rights. Property is staked from the edge of the right of way on the line that would extend to the point in the center of the road. Yea, I technically pay taxes for the land under half of the road. Most of the tax bill is related to the structures on the property, and that is the way it is. Moral of the story: It varies from place to place.
