Powerflex 50gal gas water heater, 6 years old.
Noticed no hot water, dummy light flashing 3 times = TCO or pressure switch stuck open.
No problem, done this before, pulled the vac tube to blow it out, pulled the nipple and cleaned it out, checked vent, no obstructions. Still same issue.
Replaced the pressure switch, still same issue.
Pulled the vent pipe off, hooked my leaf blower up to it and let it rip. Outside air is coming out of the vent as you would expect with the force of a blower.
Hooked it back up, same issue.
If I run it with the vent disconnected... it clears the self check and fires, so I don't think it is an intake issue. As soon as I put the vent back on it dies.
The PVC vent runs 40' across the house and has a screen on it, and clearly worked this morning bc last night's flurries are melted around it. What am I missing???
