My condo has 1 tiny bathroom. I painted it about 10yrs ago with oil-based paint. It was really a nightmare using the oil-based, but it has held up fairly well. The surface has some cracking and I need to do some work on areas that had be spackled. I did not prime last time - didn't even know about that:whistling2:
I have been going through this forum for a couple of days. Found out Behr is bad, I must prepare and prime this time, and I have seen several options for what I can paint with.
I plan to wash/rinse walls with dawn solution, lightly sand, repair any old spackle and cracks.
Since I want the walls white, can I simply paint with Zinnser's Perma White? If I understand correctly it is a superiour mold resistant primer and paint in one. Is it oil based or latex?
FWIW, I have had zero mold/mildew problems in the bathroom.
Thanks!
I do all of my own painting here, I guess you guys would cringe if you saw it. I usually just knock down the cobwebs and go for it. I would like to take a more careful approach in the bathroom.
Thanks!
