Hello, new member here! I'm a DIY nut, a safety nut, and I like to take pride by saving money and knowing the job was done well.
I have been working in a freezing cold garage every winter for 12 years now and I am finally getting too old for that nonsense! I am in climate Zone 4 (Colorado foothills) and according to my figures for a 700 square foot poorly insulated garage, I need about 45,000 BTU minimum output. In electrical heat terms that is about 12.5-15kW, and the heater I am looking at is rated to pull 62.5 amperes @ 240v. I currently have a 50A 240V circuit in the garage but that is only good for 10kW. I want to replace that circuit with a larger one to handle 15kW.
Question 1: Does King Electric make good heaters? They have 15kW "unit heaters" with a 5-year warranty, but if the product is junk and I have to use the warranty often (or if the warranty is a sham) then I'm open to suggestions on a good piece of equipment.
Question 2: I have 200A single-phase residential utility service. Am I allowed to run a 15kW load on a dedicated circuit? Am I allowed to run a larger load, say 20kW?
I'm not seeing any electrical plugs/outlets rated for more than 50A @ 240V, so I assume a hard-wire install is required. The run from the mains breaker to the desired heater mounting location would be under 15 feet.
Question 3: What gauge and type of wire will I need? Looks to me like somehwere between 2-ga and 1/0-ga, but I'm not sure what type (UF, THHW, etc) and conductor count to use.
Question 4: Breaker sizing - I know that using a breaker rated higher than the wire is not allowed, and to leave a 20% ampacity safety margin. So for 15kW I should be using a 75-90A 2-pole breaker, correct? Home Depot sells GE 70A, 80A and 90A breakers. I believe that the heater itself also has its own overcurrent protection.
I welcome any advice on materials and installation!
