Want a new table saw - 8-1/4 vs 10"
4.6K views 17 replies 16 participants last post by  lenaitch
I have an old 10" Skill table saw from about 20 years ago. The fence is crap. It can't rip any boards with precision. Most saws today with a rack and pinion fence fixes that issue. I have mainly worked with 2x material and occasional sheet goods. I would like to be able to make some cabinets down the road.
I was able to snag the 8-1/4" Dewalt 7485 for a great price. Should I hold out for something like the 10" Dewalt 7491RS instead?
Is there something else I should be thinking about when it comes to blade size? I am guessing using a crosscut sled with the smaller blade will probably be limited in what you could cut.
Thoughts? Thanks.
I agree with the post above. My first table saw was a Delta 8.25". It did almost everything I asked of it. But the table is a little small. And there's not nearly the selection of blades. Blades that are available, rarely, if ever, go on sale. But it isn't too bad to move around.
I replaced it with an old Craftsman contractor's saw. It moves around my shop easily on a mobile base. But getting it outside to use is a PITA. Cuts like a dream, though. And blades are plentiful. And, it takes a dado stack without any trouble. Dust control was non existent. I've got that mostly solved with some expense and ingenuity.
#10 ·
One of the most important features that I would need on a table saw of 8-1/4" or 10" is, will it accept a dado set?
I am no longer cutting much hard maple or red oak so a portable 8-1/4 works well for me.
I am thinking of selling all the other table saws I have and getting the Flex 8-1/4" 24 Volt battery saw.
Andy.
#13 ·
In terms of blade size, you can go down but not up. I have a 10" 113 series table saw that I've had for over 30 years. I normally run a smaller blade in it but the full 10" blades are there if need be. On the other hand, you can't put a larger blade on a small capacity saw.
#15 · (Edited)
If you aren’t actively working in the trades humping the saw around, there is just about zero reason to buy an 8.25” saw.
I also would not buy a saw without a braking mechanism- currently Sawstop. More expensive, yes, but accidents happen, even to us. There was a strong push this year to mandate safety brakes- not sure where that landed.
#18 ·
#17 ·
I used a Ridgid 10" for years. It was on a wheeled gurney that loaded on my trailer easily and large enough wheels that it traversed stairways well. Prices are high at retail, but I found mine in a pawn shop for $300 making it palatable. Step son is still using it in his business, so it has lasted quite a few years.
