A video recommended running low voltage wire for outdoor up-lighting by tucking the low voltage wire in the seams (cuts) of a concrete driveway instead of trying to tunnel underneath the wide driveway. Is this code permissible? If so, should the seams with the tucked wiring be sealed with a polyurethane caulk such as Vulkem 116 Exterior Polyurethane Sealant or Loctite PL Concrete Polyurethane Caulk? Any other precautions if doable?
