I have a theory that I'd like you bounce off of someone. I'd like to be able to trace electrical wires in the wall so I know basically where they're run. I've heard that if you use a wire tracer for phone lines (see link below) you are able to locate them in a wall.
If I'm right, please tell me yes or no, you can hook this transmitter (black and red wires) to the circuit some where- outlet or fixture- which then sends a signal to the receiver. As you follow or trace the wall you'll hear the signal which shows you where the wires are run in the wall before you make holes in a finished wall.
Any thoughts will be appreciated. Thanks.
http://www.tempo-textron.com/prod_detail.cfm?cat=800&subcat=803&pid=10426
