Tempered Glass floor mat ***YES IT IS Resolved***
1 reading
7.1K views 39 replies 10 participants last post by  ajaye
OK, so I need a floor mat for my office (bedroom) short pile (very short pile) carpet.
A lot of reviews for plastic ones talk about dents slippage and cracking
(money no object as I'm claiming it)
So I was then thinking about putting some MDF down on it. But dont look too great.
Then I came across this.
Gives me the shivers, has fantastic reviews and video is good.
I'm worried about it breaking , not likly to drop anything on it, but possible, say a cup from the table
is always possible and sitting heavily on the chair, chair has rollar castors
It looks really cool $109 on amazon prime.
Any thoughts, I know tempered glass can be broken, but I'm not going to puposely go at it with an ice pick
or pick hammer.
Thanks
I've looked at those online. My biggest concern is occasionally cleaning underneath them and potential damage if it's dropped. I had a plastic mat that worked well for 20 yrs so when it needed replacing I bought another one and regretted it as the quality was no longer there. I bought a heavy carpet mat and it's working well although my chair doesn't roll as easy on it as it did over plastic.
#5 ·
I would be worried about breakage too, but the reviews don't substantiate that is a significant concern.
They mention thin pile carpeting is a suitable substrate, but the carpet is not so much the concern, it would be soft padding underneath it (are they playing word games?)
It's not so much dropping a coffee cup to worry about, it's the point loads from the chair feet. If your chair has 5 plastic rollers, like in the picture, you might be pretty safe.
Just that that particular mat is missing the extension that goes under the desk. In time, your feet will visibly wear out the carpet under the desk.
#7 ·
txs all, @SPS-1 I have a 5 plastic roller chair, although I am also going to be replacing the chair as well.
am not worried about wearing out carpet, my carpet is not in a good state anyway, (dirty-stained) but not worn.
The reviews all seem to say its good.
I don't mind plastic even if I have to replace, but a lot of the plastic ones I've heard about, get divots in them after sitting on them for a while, then you can move the chair off it ,
at the moment its a bit of friction to move the chair, "not an awful lot but hmm yeah"
My desk is not wider (longer?) so be nice to roll from one side to the other or push myself easily back and forth.
I'm also wondering now if it would make it too "wobbly" ? too "slidy" so if I sit on it will it slide away, which is the other end of the "Not able to move" the chair.
I'd need to focus on not moving around too much.
How about getting some squares or a run of click wood or vynal flooring
HMMM, now I'm not any closer, plastic sounds good but dont wanna screw around with dents
#11 ·
I used to have an office with carpet.
Plastic never made divots, but the casters on the soft carpet would eventually fatigue the plastic mats.
I never tried the glass, but otherwise I found the best bet was a piece of 1/4" hardboard, cut to shape. It would have been pretty slippery also, but was not a problem.
Even the hardboard will eventually fatigue, but gives far more life than plastic.[/USER][/QUOTE]
#10 · (Edited)
Probably depends on how good the tempering is. Car windows are pretty amazing. Glass tables are usually very good. Rounded corners are a good sign. I'd bet the biggest risk is rolling over a grain of sand just right and that shattering it- like throwing some spark plug ceramic at a car window. You could get some window tint and tint the bottom. If it does shatter, tint is surprisingly good at keeping all the pieces glued together.
There are also direct replacement office char wheels that are basically roller blade wheels that might be safer for glass.
I've used some particle board type stuff in the past that lasted several years. Like peg board but without the holes.
#12 ·
The only thing about the Car windows,
your not putting in on the ground and sitting on a chair on it, in normal use, unless something sharp gets thrown at it, or hammer put to it.
still giving me the heebee jeebees thinking about sitting on it.
I mean the demo looks great and no bad reviews
All the plastic mats I've seen inc. Staples all say that the chaiors get bogged down in divots
likng the particle board idea
I'm not worried about wear and tear even a year, I'll just expense another one, its the getting stuck in it after sitting down a few hours thats a bit peeving me
#13 ·
just realized I have some squares of flooring in my basement, with slots in them, think they were used for something my basement build by the builders,
There small squares which I can easily bring up and test out, could even cover up with some vinal covering, there quite thick so I might bang/catch my toes on them
not sure of the namne, but they have long interlocking edges
Or maybe I'l look at a rubber or similar interlocking tile or even a few interlocking garage floor tiles
I'll report back
#17 ·
@Chonks I got a set of "rollerblade" wheels, about 40 bucks from amazon, made a big difference. lifts the chair up an inch or so, but I also noticed it still kinda sticks, but now realised that the carpet is like creased, not sure how, just use, different things stuck on there, so if I want glide free, I need that tempered glass thnigy or to pull the carpet, not sure how I can ( see pic) but either way, def I would say 80% better
I believe a single narrow wheel is easier to roll on carpet than 2 wider ones
(stock photo not exact item)
#18 ·
actually, I just noticed, the carpet has little runs in intervals in several places, all running with the line of I guess the floorboards, so I guess bad underlayment or just wear and tear, carpet in my room is like from 2006, so 17 years old
only fix is replacement or the glass thingy or put down some vinal hard floor/lino or similar, guess I could tack it down. not sure how odd it would look
#20 ·
Cut the carpet back to a reasonable amount to allow for a good push back, stretch it to fit in malleable carpet transitions nailed to the floor, tap the edge down to hold the carpet. Put some Ditra down and tile the area.
#33 ·
so you glued them back to back ? because they are clickers so otherwise they would break and move, or you glued them to a piece of hardboard or something, you say you glued them down, but to what ? the flooring you glued to a piece of wood, ? it really looks good, I like it
