Hello,
Old home, unfinished basement with a sump pump and pit. Pump runs during heavy rains and spring snow melt, etc.. have had french drain consults..
Concrete slab with block walls, open sump pit, with a failed dirt drain on one side that possibly drained under slab at one time, decades ago. the slab is on dirt, no stone under it. thus the drainage difficulty.
The sump pumps into the laundry tub, then out to the sewer. I know this needs to get re-routed, and again, have had plumbers with estimates on doing this.
The sump is not covered at all.. If i have a perimeter drain put in, i have requested to not have any gaps at the wall/foundation. I have had a radon test done and was high, 5.1. I plan on having another one done soon to re-check.
So radon a concern.
If my new sump pit is covered/sealed, but the water still gets pumped into the washtub, is this putting radon gas back in the room? via the waterflow? It would appear any gas that would be discharged to the outside via a proper discharge pipe from the sump pit, would go outside, I assume that is why they say to seal the sump pit? Am i letting the radon back in the room by continuing to have the water pumped into the tub?
thanks.. dilema, and time to spend some money i guess.
So radon a concern.
