Stripped Set Screw
2 reading
21K views 18 replies 9 participants last post by  SHR Plumber
I need to take the handle off of the faucet on the bathroom sink to replace the cartridge. When I try to loosen the set screw with the allen wrench, the screw doesn't turn, but the wrench does. It's stripped.
When I ordered the new cartridge from Delta, the guy on the phone said I need to drill the screw out of there.
What does that mean and how do I do that? Is it easy to do or should I hire someone?
#7 ·
I like the above ideas....
just another...
in conjunction with a screw extractor/easy-out, you already have a part hole in that set screw 1) an easy out in a drill, going in reverse, may jiggle that loose real quick 2) a reverse drill bit should probably follow the hole in the set screw very well... and may jiggle it loose also.
I never thouht of the epoxy... guess I thought the epoxy would not provide enoungh bite.... let us know if it works.....
Can always learn something new...
Best
#8 ·
Since the handle is screwed to the existing cartridge by the set screw, I would drill out the screw like the Delta rep said. Just use a small enough drill bit so ya don't damage the finish on the handle. Be sure to pick up or order a replacement set screw. Oh, and before you remove that cartridge, make sure you have the water turned off under the sink. Otherwise you're gonna get soaked.
#9 ·
I almost never use a drill then EZ out any more.
A simple $20.00 kit I bought that has 4 different sized bits with a left handed drill on one end and an a left handed EZ out on the other and 95% of the time will get any screw out.
#12 ·
I have to go get some epoxy tomorrow. Is there a special name brand or style that I should look for?
I tried wrapping one layer of tape around the allen wrench, thinking it would make it a little tighter inside the set screw. Of course that didn't work.
I have one of the EZ-out things. But as mako1 suggested, it's quite a bit bigger than the size of the set screw.
If I try it though, I have a spare matching handle and set screw for both sides of the faucet. If I were to use the EZ-out to remove the screw, it should be alright if it does ruin the handle. But is there anything else inside the handle that would be damaged by the EZ-out?
#14 ·
It's the wrench that came with the faucet. I had it sitting up in the medicine cabinet. Also, it fits properly to loosen and tighten the screw on the other handle. Thank you for the suggestion though.
When I wrapped it with tape, the end of the wrench broke through the tape when I pushed the wrench into the set screw, so it didn't help.
I'm going to try the epoxy and will let you know if it works. Thanks!
Barb
#16 ·
If the epoxy doesn't work, I'd use a left hand drill bit in a variable speed reversible angle drill (which you might have to rent). These drill bits will cut into the set screw when they're turning counter clockwise, and normally that's enough to remove the set screw.
#17 ·
Lots of responses, unfortunately no plumbers until now. I have repaired dozens of faucets with the same problem. That is why I get the call, the HO have already stripped the screw (usually through no fault of their own) and are at their wits end. Easy outs will not work with your problem. Drill out the set screw with and OVERSIZE bit and remove the handle. Order a new pair of handles from Delta and replace. Simple, done, and you do not owe me $100.
#18 ·
Thank you for all of the suggestions everyone!
I bought some Loctite Threadlocker Red 271 and tried that. That's what the employee at Lowe's said to use. The directions said to let it set 10 minutes. It didn't work, so I applied it again and let it set for 30 minutes. It didn't harden during that much time, so maybe I should have tried the other kind of epoxy.
I ended up drilling it out for about 20 minutes and the handle came off. Thanks for the suggestion SHR Plumber.
The new cartridges are in both sides of the faucet. The new handles are on and life is good again. No more dripping.
..... Simple, done, and you do not owe me $100.
Whew! It's my lucky day :sweatdrop:. :)
