I have an addition that I am getting ready for final inspection, but when I started researching how to finish the stair case, I realized that it has some problems. It is an L-shaped staircase. The first problem is that all the steps have a 7" rise, except for the winder which is 8". The more serious problem is that there is one step where the headroom is only about 6', not the 6'8" I see listed as a code requirement.
But the inspector has cleared us each step of the way, so now I don't know if I should continue and hope for the same. I don't want to spend all the money that I will need to finish the stairs if the inspector notices the headroom during final and I end up needing to redo it again, nor do I want to specifically call the inspector's attention to it because that would involve even more time/money to fix the headroom now that all the drywall and everything is done.
What do you all do in a case like this?
