Are these receptacles proving beneficial ?
I did not watch the video. But I am under the impression Leviton is made in the USA? A Google search seems to confirm that.I saw all I needed to see at 0:56...Made in China. BUT, it is from Leviton and is UL certified. I'll wait on the reverberations.
The advantage I see is the less chance of a faulty install by the DIY'er. I have even seen some DIY installation issues with pressure plate terminals. I have read here more than once someone asking if the wire goes under the plate or under the screw . Just recently. This will alleviate any misunderstanding of how to make the connections.I don't see any advantage for a DIYer, for whom saving a few seconds over a quality screw-with-pressure-plate design doesn't matter.
And screws hold the wire by clamping pressure, so they're the same thing as well.What's the difference between Wago and backstab? They both hold the wire by pressure, one by lever tension pressure, the other by spring pressure.
Move to 'merica. They're only about $3.49 at HD here.these are expensive
Yes but not only Leviton. All manufacturers have only #14 backstabs. It's been that way for years.Is it correct these Leviton back stab can't be used with 12 Ga. wire that a kitchen requires ?
They have tabs to split the top and bottom. They can be used on a 20 amp circuit with #12 wire.Even though duplex receptacles are rated 20 amps pass through, In reading the comments the receptacles are only rated at 15 amps, making them useless on 12 gauge wire. In addition, I didn't see a provision for breaking a tab for switch control on half of one.
