I recently purchased a house that was remodeled and had an electrical upgrade done at that time. The main circuit breaker panel was replaced with a 200 amp Square D Homeline panel. I needed to a few circuits and when I removed the panel cover noticed the breakers on the right side were not fitting in the cut out, the left side was fitting properly. After I added the new breakers I tried to reinstall the panel cover and cannot get the breakers to fit within the breaker cut out.
I have pushed the breakers in as hard as I can to seat them however they will not move. I also took a claw hammer and held the handle against the breaker and smacked the head with my hand trying to move the breaker without luck.
I cannot see any reason the breakers will not seat properly and don’t know what to try next. I have removed a few of the original breakers and do not see anything wrong. I’d greatly appreciate any ideas or suggestions on what to try next.
I did call Square D technical support and they have offered to send me a replacement load center, however I would like to make sure I am not doing something wrong before going that route or overlooking something.
Pictures below will probably explain what is happening better than I can. The panel was installed upside down with the main at the bottom.
It appears to me that it is the left row that needs to move deeper to be properly installed. My concern is if there is not a good connection the potential for creating heat and a fire hazard.
panel cover fits left row of breakers or the right,however not both at the same time.
