Shutoff valve under bathroom sink…
5.1K views 37 replies 12 participants last post by  Gators_win
Probably the dumbest question you will answer today. I’m renovating our 50 year old house. In the pictures below, hot water is on the left, cold to the right. I shut off the hot water valve, but hot water keeps flowing. Why? I was hoping I didn’t have to replace these but it’s looking like that’s the best option. The cold won’t budge and the hot budges but seems to be completely stripped inside. That’s my uneducated guess. Plus those grey pipes were banned in ‘95. I got a plumber coming for something unrelated, may as well get him to address this.
I’ve dealt w/ some shut offs here and there, and just shut the water off at the main outside. I’d unhook the lines and leave the knobs alone. Almost every knob I’ve ever dealt with has been corroded and sealed shut. PB blaster (or whatever it’s called) has been very helpful in many of those instances. Guess I have to bite the bullet here. TIA for any tips/pointers
#4 ·
I just watched a couple of videos on replacing these valves. It looks pretty straightforward. My only concern is how tight you tighten the new compression nut. Also, do you go with compression or sodder fitting? Consensus I gathered from the internet is most DIY’rs use compression. Dealing with pressurized water can be scary, but with the multitude of great walkthroughs on google, anything is possible.
I love doing these type jobs, learning something new. Not much better than working with your hands. Thx for the advice!
@Matt1963 -would the picture below work for me? I don’t know how much exposed pipe I’ll be working with until I get in there. That’s another concern. Would be awful if I cut it short, leaving not enough to work with. Assuming it even needs to be cut? 😄 this is going to be a great weekend warrior project for me.
#8 ·
I doubt you'll find the answer to HOW TIGHT by reading this crap i've copied . I do recommend what i read on a box of ferrules . After finger tight turn the nut 1 revolution . I've not had that fail .
COPIED :
How Tight Should a Compression Fitting Be? Compression fittings should be tight enough to create a watertight seal but not so tight that the pipe warps or the thread is damaged as this could encourage leaks and make the fittings much harder to remove later. Proceed with caution.
A Complete Guide to Compression Fittings
#12 ·
@Matt1963 Close up shot. Might be a job for a professional. Looks like it’s fused together. I’m so tempted to just leave it be. Shut the water off at the main, unhook the supply lines and replace it that way. Thing is, I have a plumber coming next week for something unrelated. May as well just have him deal with it. I’ve done the toilet, floor and soon the vanity. Saved a good chunk of change. What’s a couple hundred dollars for a couple of valves?
@bob22 I’m definitely changing the supply lines.
@Grounded-B I didn’t know that was a thing. So there’s faucets that you can’t shut the hot water off? Why would anyone want that? That could be the case here but more likely it’s just worn out. It hasn’t been serviced/replaced in decades. But what the hell do I know? 😄
#13 ·
They are soldered.
I agree, plumbers coming out next week anyway, have him take care of all that.
#17 ·
Well I’m back with another question. The sewage line has what looks like an adapter on it to angle it one way. The vanity I took out had an offset sink so that’s why it’s like that. The new vanity is not offset.
Please tell me there’s a workaround. No way that adapter is coming off right? This is probably a simple solution but I’m not a plumber so what do I know? The angle isn’t too bad, do I even need to do anything at all?
#18 ·
Looks like you have just enough room to cut out the 22 fitting. Cut it out and the red line and buy a new 1 1/2 trap adapter which is what the blue line represents. You will need a 1 1/4 gasket.
#19 ·
Thank you @Matt196
Unfortunately, I’m not DIY savvy enough to cut that pipe. Pisses me off too because I’ve done everything else by myself in this bathroom. Toilet, floor, vanity. Everything is ready to go but this damn plumbing. I may bite the bullet and pay a plumber to just update all of this. (Like I said earlier in this thread)
I could probably do it, at least the water lines, but I don’t feel overly confident. $160 plumber will redo it all. I’ve already saved a couple of thousand as it is.
#20 ·
Thank you @Matt196
Understood. Sounds like your money ahead.
#21 ·
@Matt1963 If I may bother you one last time. (And anyone else that wants to chime in)
I’ve decided to get a plumber to deal with the sewage pipe, but I want to tackle the shutoff valves. I just need you to make me feel good abt this. It’s not rocket science, but it it’s still pressurized water and that can be problematic if not treated properly. So as you already know, the pipes are soldered together. I have watched a lot of videos on how to replace them. There’s enough room to cut them, but I can just as easily heat them up and pull them off w/ a small blow torch.
All the videos I’ve seen just show applying heat to the connection, and slowly working it off. Then, scraping clean the copper pipes with sand cloth (120 grit), and finish up with a deburring tool. Finally, attach a 1/2” compression x 3/8” compression brass quarter turn stop straight valve onto the pipe. Tighten the nut carefully, trying to not collapse the pipe, but enough to prevent a leak. Or there’s the push valve. Push valve straight back on pipe while holding part of the pipe, simultaneously, for better fit. And I think specifications state mark a line at 1” depth (shark bite). Seems to me, the push-on might be easier. I’m guessing most professionals prefer soldered, curious to know what would choose? Would you cut this pipe or heat it?
Both our houses have old valves everywhere. If I can figure this out, I will save a ton of money redoing them all myself. I’m not expecting a detailed answer for this long, drawn out post/comment. If you could just point out any tips/corrections, that would be great. I intentionally omitted some stuff like turning water off at main and other obvious things.
Thanks for taking time to give me some advice. Really appreciate it.
#23 ·
A couple of things.
My opinion is your have the two projects, supply line side and drain side effort level reversed. If it's me I would pay someone I would pay someone the supply side because it needs more experience.
The drain side, all you need is to cut the fitting off as far away from the wall as you can. Steps:
(1) cut the fitting off, if you have a saw use a saw, use the back of the fitting as a guide, if no saw you can get a PVC cable cutter which is basically some metal wire (less then $5), and cut it off. If you are worried about not cutting it at a tight angle, buy a steel hose clamp for another $1.50 and tighten it behind the fitting as a guide.
(2) clean deburr the cut end, a putty knife may be some emery cloth.
(3) buy a trap adapter with a hub end and cement it on.
Done and ready for drain connection as long as this drain is within the width of a U bend from your sink drain tailpiece. There isn't much that can go wrong.
The supply side, I would desolder them because it's always good to have extra length for the future. Personally I do not use Sharkbites but be warned that SB use requires not just the exposed length to be the socket depth of the SB fittings, you need more than that. Some copper pipes out of the wall were not secured, if you push on them they may yield a bit. Therefore you need a way to hold onto the pipe when you push the SB on to have it fully bottom. In the future when you need to remove a SB, you will have an orange horse shoe thing you insert behind the SB fittings, then your fingers go behind that so you can go forward a tad then pull back to remove. If your SB sits tight against the wall, future removal can be a challenge. I would suggest removing these valves without cutting. Steps:
(1) turn off supply hot and cold. By the way your hot side not shutting off due to single handle faucet cross over, that faucet needs service too.
(2) open faucet to relief water pressure, turn on nearby hose bibbs to let most residual water out. Disconnect supply hoses to valves, use a bucket to catch residual water until they stop completely, hopefully.
(3) use a torch to heat the connection and tease valve off with a pliers, be careful with a torch in confined space, watch your eyebrows. If there is residual water in the pipes it may act as a heat sink and not melt the solder, worse yet super hot steam starts shooting out of the pipes. This is where experience matters.
(4) wipe off excess solder on the pipe ends.
(5) either solder on male adapters and use threaded QT valves, or use compression QT valves. For compression valve don't overtighten to the point of causing the ferrule to strangle the copper pipe.
The supply side requires more experience.
#24 ·
A couple of things.
Sometimes advising a homeowner (rookie) to use a torch with the water off is a recipe for a burned down house. I really don't use shark bites except in special circumstances.... but I'm a pro....they also have better tools for removing the shark bite that doesn't require as much clearance as the plastic c clips.
In this case the shark fitting is probably best.
Uponor also makes push on fitting and there much cheaper. All push fittings are working with little to no failure rate so advising not to use them in circumstances like this doesn't seem like good advice.
Cheers.
#31 ·
One thing though, in the future make decisions and stick to them....I call it "captain of the ship decisions"
Yeah, I hear ya. I’m definitely flip flopping everywhere. I have a lot of stuff going on in my life right now, so this project doesn’t get my full attention. I’ve been taking this bathroom apart slowly. The longer it takes the more I question things. I feel good from here on out. You guys have basically typed up a handbook for dummies in this thread, and I’m very grateful for it. I will report back with the finished product.
#32 ·
The trap adapter in post #28 that you asked about is a PVC trap adapter, your existing piping is black in color and ABS. The one that Matt1963 linked in post #29 is the one you want.
As for shutting off the feed to the water heater while replacing supply valves, sometimes I do sometimes I don't depends on the nature of the work. If your main shutoff to the house is not closing 100%, and still allowing water to slowly spill out of the cut pipe ends, sometimes shutting off the feed to the water heater feed helps on the hot side. But opening a hose bibb near the shutoff most likely will do the same. This is only important because water still coming out slowly acts as a heat sink and cause problems with soldering. If you are using SB push on connectors then a little dripping doesn't matter.
