I just replaced the leaky copper water lines in my house with pex b. I also replaced the expansion tank and filled it to my water pressure which was 60 psi. I did not replace the shower valve or the copper lines going to it. I just soldered on a pex adapter. When I turned everything on, all of the other faucets and stuff worked fine. The shower valve only puts out hot water when the handle is turned about 1/4-1/3 of the way open. If I go further, nothing comes out. The pressure and volume are low from there as well. I made sure the valve was getting hot and cold water where it should, pulled the cartridge and soaked it in vinegar and cleaned everything and the valve moves freely. I am not sure on the brand of valve but it is a pressure balancing valve. Is there anything else I can do before replacing it? Would the pressure in the expansion tank be causing this? If I do just replace the whole valve, do I need to replace with a pressure balancing valve or can I use any regular valve?
