I'm building a shed and I want it to be fairly easily movable in case I want to move it in the future, so it's being built on top of 3 6x6 which sit on deck blocks that I leveled out. I decided to save work by not going below frost line so I'll just shim as required when it settles. Basically city told me I can't build it against the fense due to easement yet all my neighbour's sheds are there. They're on super crackdown mode on bylaws right now so when that slows down I might move it to line up with the neighbours so it does not look so out of place.
Problem is, we get lot of random wind bursts here so I'm wondering if I need to anchor it to avoid it getting tipped over by the wind or do you think a typical shed would be heavy enough to not be an issue? Not really sure how strong the bursts actually are, maybe 100km/h for like half a second? Total guess though. I just know when they hit, the house makes lot of noise. It's like it's being hit by a truck. Trees outside will be bending and shaking violently for maybe 1 second then it stops and goes back to calm. These bursts hit without warning every now and then.
This is the base now:
Idea of this base is that the 6x6 is not really considered as part of the shed, it's just a solid level surface for the triple 2x6 beams to sit on while concealing the blocks for aesthetics (probably put lattice around or something). I want to be able to move it if ever I choose to so I would jack it up, take the 6x6 out and place them in the new location, level them, and then drop shed on top. But then I'm also wondering if I should find a way to anchor it but need to be able to easily unanchor it so if I put tie downs from the beams once the floor is in it would be hard to undo them. Or would filling the centre joist cavity with concrete actually weigh it down enough so it has a lower centre of gravity? Or am I worrying too much and can I just leave it as is? The shed will be 2x4 construction with 1/2" plywood sheeting. I will probably double up the floor.
