We had Pella casement windows installed in out home in, IIRC, 1984 and have loved them. That said, I am wondering what the service life is -- particularly the frame-to-sash "gasket" or seal" -- and if there is a way to replace the part and not the entire window. It recently felt a bit cold around a window and while I do not feel a draft (perhaps just radiated cold), I might try a draft test, perhaps using incense as I do not smoke.
If I do find any draft, does anyone make replacement gaskets/seals? I do know that once when I contacted the local distributor about a broken crank actuator, I was told Pella no longer provides parts; yet, I found the item elsewhere on-line. I presume if I contact the Pella distributor I'll be led in the general direction of replacing all the windows, and they still look great (we were thinking it's about time to do a light sanding and fresh coat of polyurethane on the interior wood). A corollary concern is that the inner pane, of two, is attached to the sash in a removable way and there's another gasket/seal there, perhaps I should be thinking about how long those last too.
