Hi all. This is my first post. We have some old vents on our gable roof that are unused since we got a new AC & heating unit. The shingles are in good shape, the caps are still in place and everything's sealed down tight. Drywood termites are common here so we want to prevent them from flying in and setting up housekeeping. Since we won't need a re-roof for another 5 to 7 years, is there an easy solution from inside the attic to seal the openings until then? My first idea was stapling 20-mesh screen since they can't get through that but I was hoping for something less expensive.
My partner will be doing the actual work and I'm limited to giving instructions. She's fairly handy in some areas. However, since working in the attic is unpleasant, I'm looking for the easiest way for her to do this. To give you an idea of her skill level, with my advice, she's done stuff like replace 3-tab shingles, maintain the cooler, install an under sink water filter and a toilet, disassemble and clean out the sink trap and replace toilet flappers.
Thanks for your help!
