Hi all,
I'll be re-roofing my cabin next spring. One of the problems I need to fix before the new roof would be the sagging soffits (see attached pic). The overhang is framed different than what I am used to seeing. There are outrigger type brackets at the high point, mid point, and bottom of the gable end. The sub fascia board spans between these brackets. I'm assuming these things sagged over the last 70-80 years and allowed the overhang to sag.
Is my best bet just to rebuild the brackets and install new fascia/soffit? Is there a better way to retrofit? I plan on ripping off the plywood soffit anyway and going with aluminum, so I'm not afraid of a little work.
Thanks for the help.
