Water is running down a hill from my neighbors downspouts. The water goes under my porch and is ruining the porch footing. Is there something I can put in the ground to block that water and redirect it into a drain pipe?
How far is your neighbors downspout from the property line?Water is running down a hill from my neighbors downspouts.
The water goes under my porch...
There should already be something there to prevent this.....in the ground to block that water and redirect it...?
Might cost you the hundreds, if not thousands of dollars then instead.My neighbor would have to pay hundreds if not thousands of dollars because he has two downspouts that drain on his concrete driveway.
i am planning just such design. but using a patio to do it.Install a swale on the property line.
go see my patio thread for what i am planning.I'm not sure I understand how you can build a patio on that spot
