You ever make one of those mistakes in judgment that just keeps coming back to make you miserable over and over again?
I just can't seem to shake my terrible judgment call on running the water lines. I should have run them under the slab with the rest of the roughed in plumbing like everybody does around here in Oklahoma....but I didn't. Long story, you don't want to hear it.
But I'm here now.
So...I have done plenty of pex in the walls on this house, 90 degree corners, all that, no connectors, all one piece runs. I am trying desperately to avoid running any lines in the attic space, worried about freezing lines and all that.
But I'm stuck here trying to get the water lines across this exterior door threshold to the utility closet area where the main water line comes in. You can see we have the lines in the attic space - that's temporary, or at least I was hoping.
How would you guys route these lines? I've thought about putting a piece of crown molding up at the ceiling and hiding the lines behind that to get across the door frame into the utility closet framing. I've also thought about building a soffit, but I sure hate soffits.
There is a little space between the door jamb header and frame header, like about 1" or so, and I could hide lines in there. I don't like that though, too easy for someone to not know any better and run screws up in there and...
I just don't want to leave scooby snacks for downstream homeowners...
But I'm here now.
