Replacing Windows In Brick House
1 reading
13K views 5 replies 3 participants last post by  huesmann
I have existing sliding aluminum-frame windows in my brick house. There's a brick sill, with the bricks oriented slightly downward and perpendicular to the wall. Kind of like this (except with aluminum framed windows):
On the interior the windows are framed with casing like you find around a doorway, so the interior opening is about 3.5-4.5 inches smaller than the brick exterior opening. Looks like this (except aluminum-framed):
I'd like to retain the existing interior sills. What kind of replacement window frames do I get? Do I get block frames such that the interior frame is just smaller than the sill, and fill in the exterior frame with wood? Or do I get Z-bar frames?
Thanks for the response.
There's about 3/4-1" of frame around the window, inside the sill. There's also a storm window on the outside, with a separate frame.
I did have some of the windows replaced a few years ago (couldn't afford to have them all done at the time) and it looks like the installer used block frames. It looks like he covered the gap between the exterior of the block frame and the brick with some plastic/vinyl trim pieces (kind of like in the first picture I linked). Where can one get these trim pieces, and what are they officially called?
