It has been confirmed that these tiles are asbestos and I think it would be best to cover them rather than remove them. The tiles are covering half of the upstairs of my home. Currently they are covered by carpet that is worn out and past its prime. Because of dust allergies and pets I would like to have no carpets in my house. Since these are bedrooms, wood is the ideal replacement, but I'm not sure what needs to go between the wood and the tiles. I would like to put down plywood but don't know how that could be done without disturbing the tiles. I also want to add as little height and weight as possible. (I am ok with shaving the bottom of my doors off if necessary.)
I really do not like the look and feel of any kind of vinyl plank or laminate wood materials and just want to have plywood. I am thinking of cutting the plywood to make large "tiles" that are designed to look appealing geometrically, but I don't know if I need to put something down like OSB to act as a subfloor before I do that.
The other problem is that the asbestos tiles have already been stapled and nailed by whoever installed the carpet, and I will avoid taking any of those out. I will have to remove the padding, since its way too soft and thick to go over. (It is 13mm stainmaster memory foam.) I think I can cut around the staples and avoid them, since there aren't that many - about 1 staple per every 4 sqft. The tack strips are more complicated, as they are nailed into the tiles. I think I will just leave the 1/4" tack strips and incorporate them into a subfloor structure somehow. Maybe add 1/4" of something to fill the gaps, I don't know. The idea is that the tack strips might provide me with just enough material to put very short nails or screws in to keep stuff from shifting around.
I anticipate needing a lot of glue for doing something like this. It seems like the tiles are in good enough condition that sealing them with redgard or epoxy would be overkill, so I thought maybe felt or rosin paper will be enough.
How should I go about doing this, and what do i need to avoid when it comes to putting new material down? Considering nails and screws are not an option, how would I glue in something without making new problems?
