Removing closet walls under staircase
1.6K views 12 replies 3 participants last post by  Half-fast eddie
We would like to remove this giant closet in my sons room. The walls are under the stairs. Any idea if this are supporting the stairs or load bearing? Tips or advice appreciated.
There is a chance that the floor was built to take all the load but most of the time they take the cheaper route and make that wall or a post a the corner load bearing. With out seeing the original plans it would be some considerable destruction to prove it one way or the other.
Here is a sample where they put beams around the stairs but still use that corner supported from below, and there is a header for the top of the stairs
But it can be framed in the floor like this one,
Just to investigate what you have would mean a fair amount would have to be opened and there would be a good chance of a disappointment.
#4 ·
Thank you that helps a lot! If we opened it up anyways and discovered the front was load bearing like the first picture could we still take out the rest of it and leave those posts? I could always make it into a reading corner or something else. It would still give him more space instead of a giant closet he would never use.
#5 ·
Maybe, more investigation for that.
Are there walls directly above that section which would add to the load?
Do you know the direction of the joists?
Usually but not guaranteed when the lower wall is load bearing there would be a single joist next to the stairs. And when the wall is not load bear the joist would be double.
You might learn a lot by taking down some of the ceiling at the corner, I have marked it in red.
