I had one side of my house where the gutters were not sloped properly and water started sagging the gutter. The length of the house side is 70'. The problem was right in the middle. I know I don't need to state this for you pros out there but, with the weight of the water causing the sagging, water was flowing back toward the house and both the 1" x 6" fascia and 1" x 2" trim became rotted. Now that I've removed all of the gutters around the house I see more rot in other areas.
I was planning on replacing the 1"x 2" trim that is rotted. I logged on here and saw an older post where another homeowner had gutters replaced. The company that replaced his gutters entirely removed the 1" x 2" trim and did not replace it. The gutters were applied onto the 1" x 6" fascia.
Is removing the 1" x 2" and putting the gutters on the 1" x 6" fascia a good thing (the right thing) to do? Was the gutter company in that instance just being lazy in not replacing the 1" x 2"?
I will be repainting the 1" x 6" fascia before new gutters go up, but I am looking for advice on the 'right' thing to do about the 1" x 2" (since I don't understand the purpose of this extra trim on the fascia.
Thank you in advance for your replies.
