Hi, just came across this forum, and not sure what section to put it in, sorry if in the wrong place.
I have several pieces of different wood that I want to keep and use, and they were to be used in a project that got abandoned at literally the last second. The epoxy adhesive cured on them. I went out and bought a Rigid (Home Depot) brand random orbit sander, model R2600. The roughest disks I could find were a 60 grade. I tried the sander, on the highest speed, and it only sanded the wood with the lightest amounts of epoxy, and that still took some time and doing and several sandpaper disks. I had to apply a little pressue, even though you're not supposed to.
I tried the heavier epoxied pieces and the sander just won't do anything with them. Should I take the orbital back and get a belt sander? Wish the guy at the store would have recommended a belt sander, if needed. I since read belt sanders are much more aggressive. I need to stay in the same budget range, the orbital was $69, and I see there's belt sanders for that price. Should I exchange for a belt sander? The epoxy is like a thick plastic coating on some pieces. Any other recommendations? I want to keep the wood, as the other side of the pieces is art related. Thanks.
