I have a Hitachi NV65AH nail gun that is not firing nails when the trigger is pulled. There is a continuous hiss of air, but nothing happens. I suspect that this is an issue with o-ring failure. Do o-rings go bad if the tool is not used for a few years (hasn't fired since fall 2022. Also, I have read that the tool should be stored in a warm place ... is this because the o-rings can be damaged by cold? (Columbia space shuttle accident comes to mind).
Finally, if I take the tool to a service center ($120 + parts) will they mostly replace o-rings (and some cleaning, I suppose)? I have seen videos showing DIY repair. I am not a mechanical savant but have had some success repairing things ... is the repair as simple as taking apart, replacing O-rings, and reassemblying?
Thoughts?
Thoughts?
