Problem painting Lowe's pre-finished trim
23K views 3 replies 3 participants last post by  Lazy_Jake
I recently bought Lowe's pre-finished Polystyrene white oak trim for around my interior doors. I had the assumption that the finish on these trim pieces were already primed and ready for paint. I started painting one piece of trim and found that the paint did not want to stick to the surface of the trim. The paint would would lay on alright, but the paint would then retract leaving spots all over the board uncovered, as if the paint is not bonding to the surface.
Anyone want to chime in as to what I'm doing wrong before I attempt anything else?
The main thing you're doing wrong is assuming.....:whistling2:
Prefinished means exactly that, it's finished and ready to install.
Preprimed means it's primed and ready to be finished with a topcoat.
Obviously the paint you chose is incompatible with the existing finish, so
the choice now is either return the trim and buy preprimed, or prime your prefinished with a good bonding primer so it will accept the topcoat. Zinsser Bullseye 123 will work fine.:thumbsup:
Yep 1-2-3 should bond and allow any topcoat you want. Personally, I've used this stuff in wet areas to prevent rotting and never had any issues painting it. Of course the paint did not also come from Lowes. I usually use P&L Accolade or Davis Perfection. Neither of them has ever really need primer to coat this stuff.
