Just looking at options for trim on my new shop.
I used PVC (Kleer) trim on my house. I have noticed the gaps open a lot in winter. Never seem to go all the way close in summer (though we had butted the pieces fairly tight).
So, I am thinking I may have made a mistake ......
I was given a sample of "bear board". HDPE (plastic) with mineral filler .... Black! The color I was looking for!
On a 12 ft board, according to the spec sheet I will get almost 3/4" over expansion over 100 deg.
We do get that plus a bit. We can hit -30 ... and get up to 90 (we average 5 days above 90 each summer) .... high of 12 today (-1 with chill factor) ... 5 tonight (-8 with chill factor).
So they suggest leaving 3/8" gap on each end.
That means I would need to leave 3/4" gap between two boards.
Two questions come to mind ...
1) What do you do at the ends ... make some kind of slip joint? You would not want to see right through and the idea of the trim is to protect the boards behind.
2) Why does this not pull the nails out or "oil can" ... or will it? I am thinking if you nail a the trim say every 12 ". it would "grow" and either push out all the nails ... or expand between the points where it is nailed and "oil can".
If it did this, no one would use it.
Maybe I should have done something different with my PVC trim?
What am I missing ???
Thanks ..... Mike
Thanks ..... Mike
