Apologies for the silly questions that follow. Every single breaker I had installed previously was a plug-on neutral, so I never had to deal with this before. Frankly, after this experience, I hope to never deal with it again. Siemens, get your crap together and start making plug-on variants for all amperages already.
Anyway, here’s my two 30A GFCI breakers, installed:
Thanks for the advice.
- The length of exposed neutral wire here is just what came in the box with the insulation pre-cut. Is it fine to leave it as is or should I trim it to not have so much wire exposed?
- The pigtail length is similarly as it came in the box. You can see from the location of the breaker and bar that I don’t need this much. Should I cut it off? My concern is that it’s not like this wire can be replaced. Once it’s cut, it’s done and you can’t reposition the breaker later if needed. What’s the recommended way to do this?
- Finally, these breakers came with flathead lugs to hold down the wires. Wtf? Every single other Siemens breaker I’ve seen in my life, including the plain non-GFCI versions these replaced, had square drive that allowed for proper torquing without stripping out the lugs. Is there someplace I can get replacement ones that have square drive for these? I already managed to start stripping the screws on these.
