PEX with copper stub-outs
19K views 6 replies 4 participants last post by  RippySkippy
If you had a choice how would you attach the shut-offs to 8" pre-formed copper stub outs connected to PEX.
The two options I see are: compression, and sweat on. I've never been a great fan of the compression method and while I have done it in the past it seems like a hack method. While I like to sweat copper, the heat makes me a bit nervous. If I went the sweat route, what kind of a heat sink could I use to stop the heat transfer to the pex connection? A wet cloth around the copper pipe?
What do you think?
I've done it with no means of cooling the pipe. As long as you're careful not to overheat the pipe, you'll be fine. If you still don't want to risk it, a wet towel will do the trick. The funny thing about those factory stubs they make...I know they tell you not to solder any closer than 16" away from a pex connection, but then they make those stubs about 12" long.:no: :laughing:
I actually like to make my own stubs with copper tubing and drop-ear 90's I stub out the wall and run the copper right down throught the plate/subfloor - it's much easier to secure and make it all come out neat that way, and you don't have that concern when you're ready to do finish.
#7 ·
Thanks Ishmael, your right...it's odd that they don't live by their own suggestions. Over the night I got to thinking, I could get a sharkebite connector, and after soldering pressure test that run by going to the not yet connected manifold end, shark bite the run to my pressure guage set up and monitor. If it fails....hack the wall open...ugh.....:censored:
If I would of thought this through a bit more, next time I would do as you mentioned....thanks, could you get your ideas to me quicker next time? :wink: :thumbsup:
