Around 2007/2008 we had our home's interior painted and the painters used an oil-based paint for all the wood trim, which held up extremely well. We had the interior re-painted in 2016 and the designer told the painters to use an Acrylic Latex Paint instead of an oil-based paint on all the wood trim. Whether this was the correct paint to use or the painters did not prepare the surface properly, the acrylic latex paint has not held up over time. It has flaked off from wear and when it has been bumped when moving objects so now the original color (oil-based color) shows through. Also, when we had the house pressure washed before being painted, we were instructed to use the blue painting tape to seal around the windows and doors so water would not come in. When we went to remove the blue painter’s tape, some the acrylic latex paint pulled off with the tape. It’s like the paint never bonded.
After years of living with this, we have decided to correct it ourselves and to repaint the trim. After speaking with Sherwin Williams, they recommend the Urethane Trim Enamel Paint but I not sure how to proceed or prep.
My questions are…
1. Is this correct paint to use? The current layers of paint are oil and then acrylic latex.
2. Do we need to do any prep work on the acrylic latex paint beforehand? It would be a daunting to impossible task to have to strip off the acrylic latex paint, should that be required. The job would be too big for a 1 or 2 people. This is a DIY project.
Any suggestions would help before we proceed.
Thanks.
My questions are…
Thanks.
