County is on 2018 IPC.
Bathroom is the "middle room". Toilet on the left, sink on the right, shower in the back.
Room to the left is utility/laundry. Room to the right is a wet bar.
Orange stack is the existing waste stack. All the rest would be new. I do have a 2" dry vent roughed at the ceiling to connect vents to. And I can run just about any plumbing in the left/right walls, but not exactly in the front/back walls.
Rough plan, here's what I think are my errors (pretty sure a laundry group cannot wet vent a bathroom group...):
*the shower drain should turn towards the left wall to be vented before tying into the laundry waste.
*The WC might need to be vented.
*Waste stack cannot vent the lav and bar sink, so where should a vent should go on that yellow branch?
Is there a preferred order of these drains joining together to prevent any strange sounds/results?
For kicks, where might a floor drain tie into this in the left room?
Any other way to tie this all together? Keeping in mind that concrete will need to be busted up.
