This version would be a four-legged, freestanding platform. Max weight capacity 500#. I need to get up 16' and have a 6'x6' square platform. Seems there are at least two ways of doing this: Would #2 below work and be safe? I see guys who have built hunting platforms with the legs angled out for stability which makes sense for wind sheer when placing an enclosed building on top.. Would like to avoid that look altogether and have the legs plumb vertically. Since this will be an open structure, wind forces will be be minimal. Foundation 8'x8' concrete pad 12" thick OR incorporate 24" diameter footings 36" deep into the 12" concrete pad. No frost issues here. Soil is silt/clay.
1) single continuous (20') 6x6 posts with a deck built at the 16' mark and 3'-4' guard rails.
Ladder through the center from ground to 16' mark thru a trap door.
Problem = getting deck beams/girder up that high without renting equipment
2) build a deck on top of a deck. Build an 8' deck then build an 8' deck on top of that with 3-4' rails.
Question is how does the second deck get attached to the first deck? Seems second level posts would need to be placed directly over first level posts with some sort of post base attached to the floor of the first deck. But that seems like it might be a weak area relying on the first level deck boards to fasten a post base to.
Thoughts? Ideas?
Thoughts? Ideas?
