No blow out port to winterize irrigation system
1 reading
5.7K views 7 replies 3 participants last post by  gordieax
I traditionally blow out my irrigation system each fall to prevent freezing during winter. I've always blown out the system using the test cock on the right of the backflow preventer, however, after having had a new backflow preventer manifold installed last spring I've learned that blowing out using the test cock can cause damage to the valves. Looking at the exterior piping setup, there is no other port to attach my compressor hose to do the blowout. Should I have another hose bib cut into to the 1" vertical copper pipe on the left to attach the compressor hose there? The existing hose bib at the bottom would only direct the compressed air back up through the backflow valve preventer. Any suggestions are greatly appreciated. Thanks.
Discussion starter · #4 ·
Thanks for the replies. tedindystries, you are 100% correct in stating the original irrigation system installer screwed up big time not providing a blowout port; this was done over 20 yrs. ago. Also the existing hose bib at the bottom of the piping is useless for blowouts b/c it's not post backflow preventer.
A follow-up question: Why would I need both a ball valve and also a hose bib installed post backflow preventer? Wouldn't just the hose bib be enough for me to attach the compressor hose for the blow out?
Thanks
Discussion starter · #6 ·
Well I was thinking to protect the backflow unit from the compressed air, to isolate it, then open the bib after it and all the air has to go towards the zone valves. I thought that because you said " I've always blown out the system using the test cock on the right of the backflow preventer, however, after having had a new backflow preventer manifold installed last spring I've learned that blowing out using the test cock can cause damage to the valves. " Is there still a test cock? How have you "learned" that blowing out would damage a valve and specifically, what valve?
Yes there is still a test cock to the right of the back flow preventer but it has a different fitting than the old one. The new test cock is a flare fitting so in my search to find a female match to connect the compressor hose both online and plumbing sources have stated it’s not advisable to blowout thru test cock for it can damage the back flow preventer valve. Who knew?? So now I’m seeking the best way to add what’s needed to properly blow out the system.
