I have an elevated screened porch and the floor is supported by 2" x 12"'s on 16" centers. The sides are framed with three 2" x 12"s. They are close to 18' spans, unsupported in the center other than small pieces of 2" x 12"'s between then spans just to prevent twisting.
The whole porch is 18' x 18' and the perimter is supported by 10' long 8" x 8" posts (white pine I believe) about 8' apart that sit on an underlying concrete patio.
I want to put a hot tub in the elevated screened porch, either in the center or in a corner, but believe I need to shore it up. The hot tub is 88" by 88" and will be approx. 4,000 lbs with water and people.
I do not want to add additional posts under the porch as that will make the underlying patio unusable.
I've gotten differing contractor opinions on this. One guy thought simply jacking up the underside of the porch and slipping a 1/4" thick by 6" wide by 9' long steel plate on top of the two posts and under where the 2' by 12" spans are connected with metal brackets to the perpindicular framing (to prevent the metal connecting brackets from collapsing) would be sufficient.
Any help?
Any help?
