My 4 to 1 ratio might be off.. Lets do some math..
In Michigan, residential natural gas is at $17.70 per thousand cubic feet.
A 7.5kW generator running at half load will use about 73 cubic feet per hour.. so 24hrs x 73 = 1752 cubic feet.. ($17.70 x 1.75 = ~$31). That is $31 to run 3.75 kW for 24 hours. that's a lot of power by the way. I have 3 fridges and 3 deep freezers, 3 desktops, and a 6th grader who leaves all the lights on and I average about 1 to 1.2 kWh per hour. The average central air conditioner unit runs at around 3.5 kW when it is actively cooling.
Now lets look at gasoline. These numbers vary depending on which source is referenced but this should give us an idea.. Gas varies across the country, but lets use $3/gallon and you can adjust up or down based on your local prices.
A similar generator, also running at half load, will burn about 0.84 gallons of gasoline per hour.. x24hrs = 20.16 gallons. x$3 per gallon = $60.
We're not including the transportation costs to go get it.
So its more like 2 to 1 right now.. Also, price fluctuations of natural gas are seasonal and they swing about 40% from high to low. .. oddly enough, they start going up from the bottom around January, top out in August, then fall down again. The $17.70 for natural gas I used above is at the high for this year. Whereas gasoline prices seem to be all over the board..
Right now is a bad time to need the generator for natural gas.. its about 2 to 1 cost ratio.. But if the power goes out in February, then it's more like 3 to 1 or 4 to 1.
Natural gas costs more to set up but it's worth it in just not needing to mess with carburetors.. Can't tell you how sick I am of rebuilding carbs.. Even the dentist is more appealing.
