Mineral Spirits
12K views 16 replies 7 participants last post by  jsheridan
How do you know when a bottle of mineral spirits has gone 'bad'?
I was staining a couple of cabinets this evening and on the can of stain it said to clean the brush with mineral spirits.
So I found a bottle of it downstairs and poured some of it into a glass jar and set the brush I used for the stain into it.
A little while later I checked the brush by squishing it down into the jar a little bit and pulling it up to look at it.
I'm not trying to sound like a ditz, but there is something that looks like 'cottage cheese' stuck to the brush when I lift it. Is that normal and is mineral spirits supposed to look like milk? Is the bottle of it that I have outdated? I looked for a date on it, but couldn't find one.
Thanks in advance for your help.
I have never seen MS go bad. If it is used, the paint in it will cloud it, but it eventually settles to the bottom. Maybe that is what you found.
Or perhaps it wasn't MS at all. I'd say smell test it, but I bet you probably don't know that smell as well as I do-
One other thought- there is a "non flammable" MS equivalent that is white. Usually comes in a white plastic jug.
Worthless in my opinion, but it might look like that.
#9 ·
Yes, this is a white bottle of 'odorless' mineral spirits - Klean-Strip Green. The liquid is also white.
I let the brush sit in the jar of it for about 4 hours and cleaned it out with a paint brush cleaner, then some soap & warm water.
The stain never really dissolved, it just came out of the brush in small globs and it took a long time to get it all out.
Thanks for the replies everyone.
#7 ·
Yup. What you are seeing is the product you used getting partially dissolved on the bristles because you did not clean it out. If you just throw it in thinner without any cleaning that will happen.
I will use a 3 stage method- first wash gets most the gunk out, second a bit more, third I can either finish and dry or let soak ( for a short time) .
each stage can be about 1/4 cup for 1 brush..
I think cleaning oil is much easier than latex, just stinkier.
#12 ·
The only thing that Kleen Strip Green strips is you of your green. It's worthless. I bought a gallon of it once and ended up throwing about three quarters of it away. You said it came out of the brush in globs, that tells me it's not a reducer, like true paint thinner. I'm going to take a chance and say that brush is not clean and once dry will harden up. If the heel hardens up the brush is then trash or good as a paint dust brush.
#13 ·
I should have known it wouldn't be any good as, in my experience, there aren't very many "green" cleaning products that do half the job of the products they are trying to replace. I'm sure there are exceptions.
Brushjockey, I just went to check on the brush. It's dried now and as you said, it did bush out. Bummer.
