Microwave is tripping breaker
13K views 20 replies 11 participants last post by  Clutchcargo
Got a whirlpool over the range microwave thats been there for 4 1/2 years. Recently it started tripping the breaker randomly at least once a day. I replaced the wall receptical and it worked fine for about a week, then started tripping again.
I used an extension cord and plugged it in where the washing machine was and it worked fine and did not trip. So, I plugged it back where it originally was but left the extension cord (microwave plugged into the extension cord which is plugged into microwave wall receptical). That did not trip the breaker for over a week. Today I removed the extension cord and plugged it in directly and within an hour it tripped.
My question is what might be causing the breaker to trip and why would it not trip when there is an extension cord involved?
Thanks
Recently, I was called for a similar problem. The microwave outlet was worn. The plug was loose in the outlet. As soon as I replaced it, all was well.
Another possibility: What else is on that circuit? Shut the microwave breaker. Using a tester, see what else doesn't have power. It may just be a coincidence what happened with the extension cord.
Microwave got its own breaker. Nothing else shares that breaker. I have replaced the outlet already and that made it work for a week. Then started tripping. After installing the extension cord in the middle, it never tripped (used it for over a week). Removing the extension cord caused it to trip again.
#5 ·
Both breaker and outlet are 20 ams. Nothing has changed in the last 4 1/2 years. Its the same microwave which worked fine but then recently started tripping. Without changing anything and just installing an extension cord in the middle makes it work fine. Removing the extension cord and plugging it directly in the wall causes to trip. Tripping happens randomly and doesn't always happen. But it does happen at least once or twice a day while using the microwave. Ven't isn't blocked (can feel the air outside where the vent is when microwave is running).
#8 ·
Well, if the OP is 192% sure his new receptacle does not have a loose connection, is polarized correctly, no nicked conductors that are acing to ground once warmed up...then
I think he has a magnetron going bad. The longer extension cord just allows the sudden inrush current needed when the mag fires ....to settle down, and the breaker never picks up the overcurrent. Plug it back in to the wall outlet, and then the shorter current carrying length of the house wiring, and the breaker picks up the overcurrent sooner and trips.
This is my story and I am sticking to it, until someone comes along with one better. :smile::smile:
#10 ·
Why, sure. He could borrow someone's working microwave of the same output wattage size and see if it trips the breaker, while just plugged in the wall while being used. If it does trip the breaker, he has circuit/breaker wiring issues.
I would say he could buy one and refund it if not needed, but that's not nice, so no one should do what I just mentioned. :)
#12 ·
Does it trip the breaker when opening and closing the door?
They have interlock switches - 3, two normal ones and a monitor switch. they're designed so that if one switch fails, the monitor switch shunts power directly to neutral intentionally to blow the fuse in the microwave - but in some cases the breaker may trip instead.
Reactions: mpoulton
#16 ·
Please identify the breakers used on both circuits ?
Are they just standard over current breakers ?
Or are they gfci
Or are they afci
This is important !
Normal breakers. Same that were used for the last 4 1/2 yrs. Nothing has changed except the tripping part.
Yo make it clear, sometimes it runs for 10 yo 15 mins then trips and sometimes it trips within 5 to 10 secs. No pattern I've been able to find so far.
#21 ·
I'll hazard a guess.
I suspect the cord for the microwave has developed a slight short over the past 4 1/2 years, an arc fault. When you plugged it into the extension cord, you moved the cord and in turn positioned the conductors in the cord to remove the short.
