I have a metal duct connecting the exterior through a basement wall to the oil furnace. The connection goes into the front of the furnace where the controls are and the cover for the furnace has a square hole on the bottom left as seen in the pictures. I fear it is introducing very cold air into my house (Boston) and causing more energy consumption during winter. The ocassional furnace cleaner or energy auditer have said it is not necessary you can remove it or said the furnace requires this oxygen or its life span will decrease. Mixed suggestions...
Should I remove the duct and patch up the basement hole?
Some details:
I have noticed white substances on the basement wall. I imagine this is because their is too much humidity in the basement. Maybe the hole is causing it.
1995 house so I assume just as old system
Forced air oil furnace system
Basement is divided by a wall, the other side is a garage.
2 living floors and attic sit above the whole basement including the garage
Fiberglass insulation on basement ceiling and against dividing wall. Where the foundation meets the house framing has been foam sealed.
Whole house humidifier is connected to furnace but I have never used it.
Thank you in advance. Any help I can receive is extremely valuable to me.
Some details:
